Hello everyone! I need some help getting my Ubuntu MATE 16.04.3 OS to share folders. When I click on a folder that I would like to share, there is no “local share option” when I right click. Is there a way to share folder?
Thank you for your help!
That's the thing I don't have the option "Sharing Options" in the context menu.
You installed caja-share, logout, login, and right-click on a folder does not show Sharing Options ?
what does apt-cache policy caja-share
show?
it shows
wookie@Nook:~$ apt-cache policy caja-share
caja-share:
Installed: (none)
Candidate: 1.12.0-1
Version table:
1.12.0-1 500
500 http://ca.archive.ubuntu.com/ubuntu xenial/universe amd64 Packages
Thank you pavlos_kairis! I installed caja-shares and all it good
Thanks for the help!
