I set up a shared network using Caja. I have no issue connecting if I enable Guest Access. But if not enabled, I am unable to establish a connection. I am using the u/p as set up on the host machine. If I leave u/p blank, I am not even prompted for one when trying to make a connection. I would prefer not to allow anonymous connections. Any suggestions?
Update:Still no luck. I tried Nautilus (because it worked setting up shares in 12.04) but the same results as Caja. I also noticed that the drive with root is the only HD that a share can be made. Even Gust Access did not work with additional HDs. I went to the Mate chat group, all were against a GUI setup for file sharing. I am not sure why Mate claims Caja as a tool to establish a share.
