I forgot how to show my sda1 drive using thunar?
Hey, don’t open two topics for the same line of inquiry.
If your sda1 doesn’t show on your file manager, it probably isn’t a data partition. Probably unformatted, or it is the swap partition. You can see you partition list with lsblk from a terminal.
Sorry about that. Did not know that i had.
