I upgraded to 15.10 from 04 with a clean install.(Erased the disk)
Now when I installed firefox Addons(Like adblock,honey,and a few more) I noticed that none of them we’re working,any solution for this?
Did anybody experience something similar?
My extensions/plug ins have been working okay. I did a clean install as well. Mine were pulled in once I singed in with my sync account.
Did you download them afterwards or were they automatically pulled in?
Also what errors or things are you seeing that is telling you it is not working?
Continuing the discussion from Firefox addons not working since 15.10:
I solved it.
The problem was due to a bad update or a bad installation,I can't figure out how that happen since its came with Ubuntu Mate packed,but whatever.
For others that experience the same problem,just reinstall Firefox and its should work,if it doesn't,try older versions of Firefox.
Good luck! :]
