[SOLVED] Hibernation on ubuntu mate 15.04 systemd?
Greetings to everyone. I want to enable hibernation on my laptop Acer Travelmate 4200. it’s possible? Please help me?
Control Center > Hardware > Power Management and check the settings there:
But hibernation is not enabled by default. I want to know how to enable it.
I just found out that the package isn’t installed by default, use the following terminal command (Ctrl + Alt + t) to install it:
sudo apt-get install hibernate
I would then assume you need to check the settings again, I don’t use the feature so I don’t know exactly how it works!. :smiley:
This work for me:
https://help.ubuntu.com/stable/ubuntu-help/power-hibernate.html
Bye
