[SOLVED] MATE menu missing (15.10 beta 2)
I have a fresh install of 15.10 beta 2 and cannot find the MATE menu selections in MATE Tweak. I just have the old school “Applications, Places, and System” on the top bar. What can I do do get it back? Thanks.
SOLVED!
Enable indicators and advanced menu in "Panel Features: in MATE Tweak.
glad you got it solved.
I wish there was a warning with this setting. It will wipe custom settings. And yes, I just did it again!!
But this has removed all the links from the top bar! but not given the software center link!!??
John
