Some issues during startup and shutdown
Hi everyone,
I have been using Ubuntu MATE 15.04 for about a week now and am quite happy with it. After trying several Linux distros, Ubuntu MATE seems to offer the perfect mix of stability, looks and performance.
There seem to be some minor problems however, I experience during booting and shutting down, that really slow things down. Included are screenshots of the moments when the shutdown and bootup process hang for a while.
Can anyone identify the problems?
Startup:
ACPI error (shows up before the Ubuntu MATE logo during startup)
USB errors during startup
Shutdown:
Stop job for CUPS even though I don't use any printer?
I canā€™t help, but I can report that I get similar problems practically every day (not the CUPS thing though), plus it sometimes takes forever to shutdown or reboot. And sometimes not.
Also attached USB devices sometimes disconnect. No messages issued.
I still mostly like Mate, but it can get a bit wearing at times.
[Ubuntu 15.04 Mate on AMD64]
I know an old media centre machine (by old, I mean old - BIOS dates back to 2004 and itā€™s got a Pentium 4 with HyperThreading inside) that has the same ā€œWait for device initializationā€ hang. It has had USB errors in the past (but not like yours) and sometimes doesnā€™t even turn off after shutdown - it just halts.
The start-up hang started after the upgrade to 15.04. It didnā€™t happen in 14.04, 14.10, so it could be the newer Linux kernel having some issues communicating with your hardware, or potentially a signalling a hardware fault.
Back to the media centre I mentioned, I think something is faulty inside that machine though, like I say, it doesnā€™t power off once itā€™s shut down; and in the past has outputted something along the lines of ā€œUSB enumeration at port ## failedā€ every second (making the console unusable from all that spam) :expressionless:
Equally, this could be caused by systemd (new default init system in 15.04), so you could try the previously used Upstart (some other distros like elementaryOS still use this at the moment) - To do so, hold SHIFT while your computer starts and try the ā€œUbuntu ā€¦ (upstart)ā€ option. I havenā€™t tested this myself so I canā€™t be certain systemd is the culprit here.
Will try you method lah7, thanks.
Run
systemd-analyze blame
And see if you can spot a service that is long running.
For the first error, the "ACPI PCC probe failed" error is actually harmless. I only just realised my main machine has the exact same message (except after 2.231240 seconds) but I have no problems with power management.
I have a different kind of issue during startup and shutdown. Iā€™m on i386 15.04 ubuntuMATE. When I turn on my laptop, after pressing ā€˜enterā€™ on grub boot screen to start ubuntu, my laptop goes into some sort of suspend mode i.e. screen turns off, power button blinking orange instead of continuous green. I press it again after a minute then lights go green again, screen turns on, ubuntuMATE lockscreen loads after a while and all is well.
For shutdown issue: After pressing shutdown, screen turns off, then goes into suspend mode again (orange blinking again; and it doesnt turn off even after a while). I have to press power button to ā€˜wakeā€™ it, log screen turns on, I press shutdown using the menu again, and only then does it shutdown.
Help. Iā€™m on Acer Aspire D250 netbook. If this is related, it detects that my battery is near broken (low capacity at 48%)
