Some weird "dock" appeared in startup
Hey,
Now for some reason (maybe I did something that I dont know :stuck_out_tongue: ) appeared a weird dock in startup ON my panel on bottom of the screen. It had 4 icons, from which I could remove one. It seems to be “Plank”. How do I remove it from coming in startup?
I right clicked and clicked quit. In next login, it comes again.
Hi @johnnyrevival,
open Control Center > Startup Applications and take the tick out of "Plank":
Thanks for your answer, but unfortunately I checked that already and it did not include Plank.
Does it say “Docky” anywhere?. :smiley:
^^ haha no, docky? :smiley:
Did you install any docks by chance?
Also have a look at your home/.config/autostart
I may have added plank when I was trying different things, plank is already part of UM it seems.
v3xx, I will check later.
Ok, I found it out. It was not in /.config/autostart, but I found it in dconf / org / mate / desktop / required-components and in it there is ‘dock’, and value was Plank but I took it off and left empty, restarted and that dock didnt reappear. I do not know how it originally came, because at least from dconf I have not set it. But now its solved.
