Something similar to Unity's window overview?
I must admit I sometimes miss Unity's window overview since having switched to MATE.
On MATE, I have this:
On Unity, I had that:
Is there any equivalent to this more visual window overview on MATE?
Compiz does that. You just need to enable it
I just tried and i have this in Compiz (i usually prefer Compton, so this is just quick test)
I believe compiz also does a window switcher that is just like the screen-shot provided by orschiro.
The first thing to do is to install the following:
sudo apt-get install compiz-config-settings-manager
In there the setting to enable, if they are not already enabled are:
"Shift-Switcher" and "Application-Switcher"
See below for where to set them and how they look:
@orschiro
You are searching for the “Scale” compiz plugin, super-s shortcut by default once enabled.
Thanks to all!
I should have been more precise, I guess.
I really like the stability and simplicity of Marco and tend to not wanting to use Compiz unless I really have to.
I guess, for Marco there is no such solution?
As far as i searched marco doesn't have such thing. But i am maybe wrong.
Xfce as a good one but more like Marco default. At least, better than Compton :disappointed:
