Sort order of the devices
i have two partitions mounted as "data1" and "data2". The sort order in the caja side panel is "data2" and then "data1". Which criteria is caja using to sort the devices? I assume its the device file because every time i checked it, data2 is /dev/sdc and data1 is /dev/sde.
Aleksander
