Hi all, I have been trying MATE (Ubuntu Mate 18.04), really like it, but these two issues are preventing me from making the switch from KDE (long time KDE user):
Is there a way to disable/enable the laptop touchpad when an external mouse is plugged in? Plasma has an option for this, Gnome has it (hidden under GSettings), but in MATE I can’t find anything related.
I have tried the Ubuntu MATE live USB, and also installed the MATE flavour in one Kubuntu machine. In both, opening the sound volume indicator and using the mouse scroll wheel to raise the volume, lowers it instead. Using the scroll wheel to lower it, raises it instead. It’s the inverse of what should happen (scroll up should raise, scroll down should lower). Anyone knows how to fix it?
Thanks in advance
