Soundblaster CA0106 Help needed to get working in 16.04.1
I have set the levels in alsamixer, selected the card (won’t stay selected) but I can not get it to produce sound, any pointers???
thanks
Hi @smartnoise,
have you checked in sound preferences to see if the correct hardware has been selected/is showing?. :smiley:
Wolfman,
Thanks, yes i have but my selection won’t stay Soundblaster, it reverts back each time to the built in in but that said even when i select soundblaster, no sound.
I read somewhere I may have to delete & reinstall pulse audio?
I have set up Alsa mixer, as all the levels were 63-0, now 63-63
The actual card is a RocketFish RF-71sdcd, basically a rebranded soundblaster.
HI @smartnoise,
do you have onboard sound enabled in BIOS, that might be part of the problem, disable it if you can?. :smiley:
I disabled it, still no go…
And did you check the sound preferences settings as well afterwards to see what is in the hardware list?. :smiley:
I did, hardware is selected, still no sound. I am reading that SoundBlaster is not well supported on Ubuntu? Bummer, any recommendations for cards that are?
Hi smartnoise
I do not run Soundblaster, but found this dated fix that may be worth a try. Got some other hits here.
Good luck :slight_smile:
Thanks, I shall try when I get back home…I’ll report back
