I would like to find out the total amount of space used by my home directory and all files in the subdirectories.
Using Thunar, I went to my home directory and selected all, but it does not give the correct amount of space used.
I tried du -h, but it does not give a grand total.
du -h -s gave me 3.6 Gb. Is there a limit to how much can be in my home directory?
I have read of others running out of space in that directory.
You can use MATE Disk Usage Analyzer (Applications -> System Tools).
Mickey
df -h
will show you the different partitions of your filesystem. If you have a /home mounted to a separate partition, you are bound by the size of that partition. But if you just have one partition (/) for everything (/home is included in there), then you’re bound by the size of the whole disk.
case 1 one disk partition sda1 for everything
/dev/sda1 140G 9.7G 123G 8% /
case 2, one partition sda1 for /, another sda3 for /home
/dev/sda1 100G 30G 70G 33% /
/dev/sda3 20G 5G 15G 25% /home
Are there benefits to have a separate partition for /home? yes, you can easily keep/backup your files and have different distros installed in the first partition. Disadvantage is you have no idea how big /home will become so when you install, you have to think ahead should I make my /home 50G, 100G, I don’t know. /home can be on a different disk if you prefer, one disk for the OS and one disk for your /home (sdc1)
There are ways to expand your /home and make it larger after install, assuming there is room in the disk (sda). That process is a bit involved but it can be done. Hope this helps.
/dev/sda1 1.6T 13G 1.6T 1% /
So I guess I have plenty of room.
Would there be any advantage in making more partitions even if they are not used?
I currently have a 2nd empty partition.
I also like qdirstat, which is similar but much faster.
