Start compiz per script instead of MATE Tweak
Hi all,
I made a small script with basic settings on new ubuntuMATE installations. I would like to set compiz as the default window manager. Because of that I need to activate compiz with a bash command. The following command does not work (https://wiki.ubuntuusers.de/Compiz/):
compiz --replace &
Can anybody help?
Many thanks.
Hi corano,
Sorry if this turns out to be no use for you. But with the Compiz Reloaded I’m using the command to start compiz is compiz ccp --replace
Hi Alif_Dal_Mim,
thanks for your reply. There are 2 problems with compiz ccp --replace:
  • The menu in MATE Tweak shows still the old window manager (‘Marco’ in my case )
  • The terminal shows a warning: compiz (decor) - Warn: No default decoration found, placement will not be correct
And it seems that the method with MATE Tweak is doing something more because it takes a little bit longer (about 3 sec instead of 1 sec with commandline)
Hi @corano, not sure if this helps as I got playing with the 17.10 structure of settings.
I did find the permanent setting that corresponds to the MATE-tweak setting. it doesn’t change window manager on the fly but makes it permanent thus active on next reboot or addable to your script, of course.
gsettings set org.mate.session.required-components windowmanager compiz
I hope my assumption of 17.10 is correct. gsettings is nicely command-completion friendly.
Hi @Bill_MI,
Wow! Great! That seems to work!
And it works even with logging out and in again, without rebooting. I tested it with UbuntuMATE 16.04.3.
I knew gsettings, but it’s sometime not easy to find the correct option :slight_smile:
Many thanks!!!
another method to activate the changed setting without rebooting is the following command:
gksu service lightdm restart
Bye…
Great! I thought you also wanted to change on the fly.:slight_smile:
As for gsettings, there’s a GUI dconf-editor that I’d been using for so long I didn’t realize how gsettings had become super command-completion friendly. It completes key names, too.
The reason I was looking in 17.10 was dconf-editor port to GTK3+ has forced it upon me. 16.04 still has the old dconf-editor. But I like what I see with gsettings.
A way I handled this previously is to make an autostart script which I can edit in shell via nano when things go wrong.
