Startmenu higher fade-out time possible?
Here I have a gif of what i mean: https://imgur.com/a/K529k
You can’t go diagonally in the menu with your mouse to open a programm because the submenu will fade out
before you reach it.
You first have to go horizontal and then can go up or down. That is absolutely not intuitive and
it is one of the things I hate most about Ubuntu Mate!
The fix should be pretty easy. The subemenu fade-out time needs to be higher - at least for the people who
want it to behave that way.
Is is there a way or will it be maybe considere as a feature in the feature?
thanks
YES! This fries my brain on a daily basis.
Goodnes, that is annoying!! That menu really needs some love.
Would you be up for filing a bug in the mate-panel repo? Post that gif too, please, as it’s very useful to explain the issue. Thanks! :slight_smile:
