Hi, my first post,
i have two make files, one building a static library, other is to build with lib linking
when i use make for 2nd file i am getting linker error
/usr/bin/ld: skipping incompatible …/development/lib/libstat_cpp.a when searching for -lgurux_dlms_cpp
/usr/bin/ld: cannot find -lstat_cpp
collect2: error: ld returned 1 exit status
makefile:27: recipe for target ‘bin/client.bin’ failed
make: *** [bin/client.bin] Error 1
anything i am missing?
make file1:
Generate STATIC library.
TARGET = libstat_cpp.a
CC = g++compiling flags here
#CFLAGS = -O3 -Wall -fPIC
LINKER = ar rvs
linking flags here
LFLAGS =
change these to set the proper directories where each files shoould be
SRCDIR = src
OBJDIR = obj
LIBDIR = lib
SOURCES := $(wildcard $(SRCDIR)/.cpp)
INCLUDES := $(wildcard $(SRCDIR)/.h)
OBJECTS := $(SOURCES:$(SRCDIR)/%.cpp=$(OBJDIR)/%.o)
rm = rm -f
$(LIBDIR)/$(TARGET): $(OBJECTS)
@$(LINKER) $@ $(LFLAGS) $(OBJECTS)
@echo “Linking complete!”
$(OBJECTS): $(OBJDIR)/%.o : $(SRCDIR)/%.cpp
@$(CC) $(CFLAGS) -c $< -o $@
@echo “Compiled “$<” successfully!”
.PHONEY: clean
clean:
@$(rm) $(OBJECTS)
@echo “Cleanup complete!”
@echo $(OBJECTS)
.PHONEY: remove
remove: clean
@$(rm) $(LIBDIR)/$(TARGET)
@echo “Executable removed!”
make file 2:
project name (generate executable with this name)
TARGET = client.bin
CC = g++
CFLAGS = -c
LINKER = g++ -o
linking flags here
LFLAGS = -L…/development/lib
SRCDIR = src
OBJDIR = obj
BINDIR = bin
rm = rm -f
$(BINDIR)/$(TARGET): $(OBJECTS)
@$(LINKER) $@ $(LFLAGS) $(OBJECTS) -lstat_cpp
.PHONEY: clean
clean:
@$(rm) $(OBJECTS)
@echo $(OBJECTS)
.PHONEY: remove
remove: clean
@$(rm) $(BINDIR)/$(TARGET)
