Is it possible to activate the sticky notes applet on the cupertino layout?
I have searched through this forum and tried to find any relevant settings in the control centre or by right clicking the top panel, but no luck so far.
Hopefully someone has got this to work and can share their wisdom with me!
Right click on the three dots closest to the applications menu, a menu should show on which one of the options should be move, if its greyed out then unlock the applet with unlock in the same menu then right click again select move move it a little to the right, then right click on the space where the global menu was select add applet, then select the correct applet from the list, then move the sticky notes applet to where you want and move the global menu back to where it was if you so desire
