after all the joy i’ve had with ubuntu mate "> 3 months " i decided to install another linux dist along side with mate but then changed my mind and deleted it and now i’m facing a problem whenever i reboot my system i notice swap is off unless i swap it on manually in gparted …
/dev/sda1: UUID="0a30fdea-082c-45e7-ba31-6fce897367b2" TYPE="ext4" PARTUUID="00054b56-01"
/dev/sda2: UUID="f0e06947-efba-4a36-bb42-d254ccbea6fb" TYPE="swap" PARTUUID="00054b56-02"
/dev/sda3: UUID="d40a811a-d5ca-432d-add7-fbe46ea73c47" TYPE="ext4" PARTUUID="00054b56-03"
i searched for the problem but can’t find something similiar since my fstap seems to be okay !
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda1 during installation
UUID=0a30fdea-082c-45e7-ba31-6fce897367b2 / ext4 errors=remount-ro 0 1
# /home was on /dev/sda3 during installation
UUID=d40a811a-d5ca-432d-add7-fbe46ea73c47 /home ext4 defaults 0 2
# swap was on /dev/sda2 during installation
UUID=ddb5ace1-7c19-4ca9-a5db-ae571403310a none swap sw 0 0
