Migros Photo Service - finish installation - necessary step
When you install the software via the Perl script installer and click on the icon to start the program it fails to start. There is a missing dependency.
run the following in a terminal:
sudo apt install libgstreamer0.10-0 libgstreamer-plugins-base0.10-0
Try to start the program again - now it works!
source::
https://swisslinux.org/forum/viewtopic.php?id=3471&p=3
post #62
accessed::
2017-09-16
Many thanks to the contributors on the swisslinux forum.
