Syncing a data recording device
I am a Land Surveyor in the USA and currently in the process of converting my field crew computers over to ubuntu mate. The issue I have is trying to sync a windows mobile embeded device the same way as you would an mp3 player. I can use a flash stick but I am trying to make it as simple as possible in the event that I am not there. Any direction would be greatly appreciated.
Thank You
Hi Tim,
I don't have an answer for you myself but you might want to go here:
and ask it again using the search function!.
Hope it helps and post a reply back here if you are sucessful so other users can read how you solved if the probem if you do!. :smiley:
