The man command doesn’t work in terminal. I would like to read what a particular command does, but I can’t. Whenever I use the man command in the terminal, I get man: can’t open the manpath configuration file /etc/manpath.config
Have you tried opening the “manpath.config” file with:
sudo pluma /etc/manpath.config
If you have, does it exist? If it does not, then you could instead type:
sudo pluma
And then, if you wanted to, you could copy and paste the text, below. It is the content of my manpath.config and I can confirm that “man” works on my machine. Then save the file to “etc/manpath.config”. I should provide a caveat here, however. I don’t actually know for certain whether the “manpath.config” file is configured to a particular machine or particular user. In which case, my content may not work for you. Or, whether it is a default content, in which case, yours would be the same as mine
On the other hand (bearing in mind the caveat, above), if your file does exist. Then open Caja in superuser mode and rename your existing “manpath,config” as “manpath.backup” and then make a new one with my content, as described above. If the new one works, then all is good. If it does not, then delete it and rename your old one back to its original name, and you will be no worse off then before.
# manpath.config
# This file is used by the man-db package to configure the man and cat paths.
# It is also used to provide a manpath for those without one by examining
# their PATH environment variable. For details see the manpath(5) man page.
# Lines beginning with `#' are comments and are ignored. Any combination of
# tabs or spaces may be used as `whitespace' separators.
# There are three mappings allowed in this file:
# MANDATORY_MANPATH manpath_element
# MANPATH_MAP path_element manpath_element
# MANDB_MAP global_manpath [relative_catpath]
# every automatically generated MANPATH includes these fields
#MANDATORY_MANPATH /usr/src/pvm3/man
MANDATORY_MANPATH /usr/man
MANDATORY_MANPATH /usr/share/man
MANDATORY_MANPATH /usr/local/share/man
# set up PATH to MANPATH mapping
# ie. what man tree holds man pages for what binary directory.
# *PATH* -> *MANPATH*
MANPATH_MAP /bin /usr/share/man
MANPATH_MAP /usr/bin /usr/share/man
MANPATH_MAP /sbin /usr/share/man
MANPATH_MAP /usr/sbin /usr/share/man
MANPATH_MAP /usr/local/bin /usr/local/man
MANPATH_MAP /usr/local/bin /usr/local/share/man
MANPATH_MAP /usr/local/sbin /usr/local/man
MANPATH_MAP /usr/local/sbin /usr/local/share/man
MANPATH_MAP /usr/X11R6/bin /usr/X11R6/man
MANPATH_MAP /usr/bin/X11 /usr/X11R6/man
MANPATH_MAP /usr/games /usr/share/man
MANPATH_MAP /opt/bin /opt/man
MANPATH_MAP /opt/sbin /opt/man
# For a manpath element to be treated as a system manpath (as most of those
# above should normally be), it must be mentioned below. Each line may have
# an optional extra string indicating the catpath associated with the
# manpath. If no catpath string is used, the catpath will default to the
# given manpath.
# You *must* provide all system manpaths, including manpaths for alternate
# operating systems, locale specific manpaths, and combinations of both, if
# they exist, otherwise the permissions of the user running man/mandb will
# be used to manipulate the manual pages. Also, mandb will not initialise
# the database cache for any manpaths not mentioned below unless explicitly
# requested to do so.
# In a per-user configuration file, this directive only controls the
# location of catpaths and the creation of database caches; it has no effect
# on privileges.
# Any manpaths that are subdirectories of other manpaths must be mentioned
# *before* the containing manpath. E.g. /usr/man/preformat must be listed
# before /usr/man.
# *MANPATH* -> *CATPATH*
MANDB_MAP /usr/man /var/cache/man/fsstnd
MANDB_MAP /usr/share/man /var/cache/man
MANDB_MAP /usr/local/man /var/cache/man/oldlocal
MANDB_MAP /usr/local/share/man /var/cache/man/local
MANDB_MAP /usr/X11R6/man /var/cache/man/X11R6
MANDB_MAP /opt/man /var/cache/man/opt
# Program definitions. These are commented out by default as the value
# of the definition is already the default. To change: uncomment a
# definition and modify it.
#DEFINE pager pager
#DEFINE cat cat
#DEFINE tr tr '\255\267\264\327' '\055\157\047\170'
#DEFINE grep grep
#DEFINE troff groff -mandoc
#DEFINE nroff nroff -mandoc
#DEFINE eqn eqn
#DEFINE neqn neqn
#DEFINE tbl tbl
#DEFINE col col
#DEFINE vgrind vgrind
#DEFINE refer refer
#DEFINE grap grap
#DEFINE pic pic -S
#DEFINE compressor gzip -c7
# Misc definitions: same as program definitions above.
#DEFINE whatis_grep_flags -i
#DEFINE apropos_grep_flags -iEw
#DEFINE apropos_regex_grep_flags -iE
# Section names. Manual sections will be searched in the order listed here;
# the default is 1, n, l, 8, 3, 0, 2, 5, 4, 9, 6, 7. Multiple SECTION
# directives may be given for clarity, and will be concatenated together in
# the expected way.
# If a particular extension is not in this list (say, 1mh), it will be
# displayed with the rest of the section it belongs to. The effect of this
# is that you only need to explicitly list extensions if you want to force a
# particular order. Sections with extensions should usually be adjacent to
# their main section (e.g. "1 1mh 8 ...").
SECTION 1 n l 8 3 2 3posix 3pm 3perl 5 4 9 6 7
# Range of terminal widths permitted when displaying cat pages. If the
# terminal falls outside this range, cat pages will not be created (if
# missing) or displayed.
#MINCATWIDTH 80
#MAXCATWIDTH 80
# If CATWIDTH is set to a non-zero number, cat pages will always be
# formatted for a terminal of the given width, regardless of the width of
# the terminal actually being used. This should generally be within the
# range set by MINCATWIDTH and MAXCATWIDTH.
#CATWIDTH 0
# Flags.
# NOCACHE keeps man from creating cat pages.
#NOCACHE
The manpath file exists; I tried your suggestions, same results.
I read it. I have no idea why it won’t work.
Are you running apparmor? (Edit: It’s enabled by default)
systemctl status apparmor.service
What’s the contents of:
/etc/apparmor.d/abstractions/user-manpages
If it exists but the error message says you can’t read it then it means the file ownership / mode is screwed up.
ouroumov@Bloc:~/Desktop$ ll /etc/manpath.config
-rw-r--r-- 1 root root 5170 nov. 7 2015 /etc/manpath.config
And if config exists and is readable by the user, then it could be related to AppArmor. Tell AppArmor to put compaints in logs but allow the command with:
sudo aa-complain /etc/apparmor.d/usr.bin.man
and see if that helps.
I reinstalled Ubuntu Mate and manuals work properly now. I don’t know what caused the problem before, but everything seems fine now.
Thanks for your help.
holla it worked for me
Thank you samuvuo
