Ubuntu MATE 16.04 LTS won't boot on Raspberry Pi3
Greetings everyone!
I’ve stumbled upon an issue after writing an image of Ubuntu MATE on a brand new SD card, where upon boot the process stops with a message like this:
[1.750543] EXT4-fs error (device mmcblk0p2) : ext4_lookup :1588: inode #2 : comm systemd : deleted inode referenced : 260098
followed by
failed to determine whether /dev is a mount point ; I/O error
I rewrote the image (using gnome-disks utility while on Raspbian) a few times, formatting the SD card in between as well and the issue still remains. Do I miss something that can be done? I’m quite new to this and the search didn’t help me a lot. Would appreciate any help on the problem, thanks!
Two ideas :
1)Download Ubuntu mate image again and write it again
2)Try with another sdcard
Already did that but shall give it another try anyway.
UPD: three different cards, each one with fresh download (checked the sum with sha256sum also) and still not going
It’s difficult to work out what next in this sort of situation.
Try:
  • loading card from different hardware (might be a file-relared problem)
  • check power supply is giving enough
  • try with minimal hardware attached directly to the Pi
    HTH
This thread just stopped. I have the same problem and wonder how it was resolved
I solved the problem for myself. I used BitTorrent to download a new compressed file, did secure ftp to the pi, used Disks to put the image on the microSD card. Boot was then successful on the new card image.
