Problem(s)
- My notebook (64-bit ARM) is not booting anymore.
- My Installation is broken (it is usually running Ubuntu MATE 16.04)
Observations :
- No BIOS nor UEFI
- SD cards boot before EmmC on my notebook
- The screen remains dark after more than 10 trials to power off/on with the upper right button…even when holding the shift/CTRL button
Cause :
I think it is because of these commandlines
$ wget https://github.com/ayufan-rock64/linux-b..._arm64.deb
$ dpkg -i linux-image-4.13.0-rc1-rockchip-ayufan-93-ga1d4fc4_0.5.5_arm64.deb
$ sudo grub-reboot 1 ; reboot
Resolution
The actions I took were :
- attempt to partition an SD card to boot on Grub( partially failed)
- verify whether I had Synaptics, apturl or else (success)
- verify if Grub was installed (not installed)
- change from apturl to synaptic (success)
- verify the distribution (but I suspect the command has been forged to pretend it was Kali Linux) and it seems to be an Ubuntu MATE 16.04
- download boot-repair and Grub (success)
- double-click on the zip to install boot-repair and Grub (fail)
- enter the commands that broke my installation
- try to reboot holding shift/escape (fail)
Solution(s)
- Replace (a part) of the Kernel ?
Kenzucky
