YEAH! I did as you said. I added a # and it works...
Thx !
W
Thx !
W
Sorry I missed that (it was in the details I said you'd have to wait for others).
I'd just edit the file with your preferred text editor (vim, nano etc) and add a "#" at the start of the line. Note you'll need to use elevated privileges to edit the file (ie. the edit command will require sudo).
