Gordon, sorry, I know some people are fussy re code, and my way has always been to bold any bits not being actually pasted as a block, as in for use by others, or showing the contents of a file or entry, merely because it is so much easier to see when inside a paragraph. OK, rereading that, I see you are saying to mark the file contents as code, not code inside paragraphs, so no worries.
OK, those .desktop files are pretty damned ordinary - worked for YEARS in Gnome and KDE, and having changed the nautilus to caja recently still no problem (as there shouldn't be), except in MATE. So I will give you contents of the single daily_folder.desktop file that runs a script to open the 3 folders (the same script my panel launcher invokes, and which MATE doesn't have a problem with):
[Desktop Entry]
Type=Application
Exec=/home/ozzman/bin/daily_folders
Hidden=false
X-MATE-Autostart-enabled=true
Name[en_AU]=My Daily Folders
Name=My Daily Folders
Comment[en_AU]=Open Android TV, Completed Downloads and Cache folders
Comment=Open Android TV, Completed Downloads and Cache folders
X-MATE-Autostart-Delay=60
I changed the Autostart part to true, but it's actually set to false because MATE can't handle it, even with the minute delay.
