Ubuntu Mate Installation
Hi, I’m trying to installation Ubuntu Mate but I can’t do.
I using Win32DiskImager.
Raspberry Pi and MicroSd are ok, because I have install Raspbian
What I can doing?
This is what I use if i am trying to set up a Linux USB while in Windows:
you remember what settings you have chosen?
This program requires an .iso file but ubuntu mate is in .img format
ah right, sorry, I didn’t realize
I have never tried it with windows but you might check out unetbootin
This might help?:
https://wiki.ubuntu.com/ARM/RaspberryPi
Thanks for your help. I resolved, I used the safe removal of the SD and I had no more problems :)grin:
