Ubuntu Mate Rasp3 external SSD mount/automount drives me nuts
I want to use this setup:
It works. For some seconds or some minutes.
THen Ubuntu always tries to mount the SSD a second time into another location (/media/user/EA132323 ) and this breaks the torrents/deluged.
I don’t think it is a power problem. It is a SSD and I have a 2500 mA USB power supply on my Rasperry.
How can I prevent Ubuntu mounting any external SSD?
When the problem occurs two processes are running that were not running before:
  1. ubs-storage
  2. mount.ntfs
Please any advice? As far as I know I deactivated any automount of storage. Also, this is totally stupid. A system should NEVER automount something out of the box.
Please, any advice?
Solved:
Power problem, solved by software config
config.txt add the line: max_usb_current=1.
