EDIT: I changed the topic, since I am now trying to configure xrandr to do what I want. Look at post #3
I need to start two instances of (at least) “mate-session” and “mate-panel” for dual monitor setup. (Need two separate desktops). This is because having separate x screens running.
Where is the script (or similar) that starts up these? I can not find, and Google does not help me.
Directions on the second link were partially wrong, but it was a good start
Here is what I have now:
xrandr --auto --output DP-0 --left-of DVI-D-0
but it gives error
warning: output DP-0 not found; ignoring
Also in the display I am using xrandr does not see DP-0 display, only way it sees it is to type:
DISPLAY=:0.1 xrandr
Anyone have idea how do I make a setting that is referred to second monitor?
Here is detailed info of those command and outputs:
when typing:
xrandr
it gives me following output:
Screen 0: minimum 8 x 8, current 1920 x 1200, maximum 32767 x 32767
DVI-D-0 connected primary 1920x1200+0+0 (normal left inverted right x axis y axis) 518mm x 324mm
1920x1200 59.95*+ 59.88
1680x1050 59.95
1600x1200 60.00
1440x900 59.89
1280x1024 75.02 60.02
1280x960 60.00
1280x720 60.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
640x480 75.00 72.81 59.94
HDMI-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
but typing:
DISPLAY=:0.1 xrandr
it gives this output:
Screen 1: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
DP-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 598mm x 336mm
1920x1080 60.00*+ 59.94 50.00 60.05 60.00 50.04
1680x1050 59.95
1600x1200 60.00
1440x900 74.98 59.89
1280x960 60.00
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 75.00
720x576 50.00
720x480 59.94
Btw, does it matter that I am using GTX 1050 and Nvidia proprietary driver, and set it to separate x screen? I think not, but but…
EDIT: this does not work: xrandr --auto --output DISPLAY=:0.1 DP-0 --left-of DVI-D-0
