I was looking for the toolbar customization settings because I wanted to set it to icons only, like in this printscreen I found online:
I could not find it on MATE Tweak:
so I browsed the user manual looking for it:
but as seen on the printscreen the features described on the manual do not correspond to the availability of those options. Lower in the manual there's what I was looking for but it does not seem to be correct. I wanted to remove the "Back" and "Forward" words from Caja's toolbar, which are totally not needed and just take up precious real estate space:
So where are these options?
