UM 24.10 no wifi
Looks to me like the initramfs loads the driver for the wireless card, iwlwifi, but the initramfs doesn't have the patched firmware.
Maybe try adding to your boot options blacklist=iwlwifi, to prevent the initramfs from loading the driver, leaving it up to the main system when it starts to take control?
linux /boot/vmlinuz-[xxx] root=UUID=[yyy] ro quiet splash blacklist=iwlwifi ---
Another one tells me to update firmware from this site:
W
It's unclear to me what happened when you tried a live USB. Your post seems to say that it fails with the same error.
My question would be - What version of the live USB did you use? If you used a 24.10 live USB you should also try earlier versions to see if they work. If they do work and 24.10 doesn't, then we can conclude it's a software problem.
If it fails with the older versions in the same manner, that would tell me it's probably a hardware failure. Aging component gets hot, breaks connection, yada yada yada. I would re-seat the wifi card if it has one.
Best of luck. It looks like you have many people interested in the problem. I'm looking forward to finding out what the problem is.
I was OK for a few days. Now the problem is back.
A few small software updates in the meantime.
same error:
31.083808] iwlwifi 0000:00:14.3: Failed to start RT ucode: -110
[ 31.083815] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 32.129354] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110
W
The USB is with 24.10 The one I used for fresh install.
W
MDD12
It didn't work either booting with a 24.04 USB. But the lspcicommand doesn't list any problem with the PCI devices
W
Guys
Just got an automatic Linux-firmware update minutes ago.
I rebooted and the wifi did connect
:sweat_smile: :slightly_smiling_face: :crossed_fingers: :crossed_fingers:
Hope it will persist
*** Note: Well it didn't. It disconnected by itself a few times since this morning. No suspend. I rebooted and it reconnected... for maybe an hour or less. Now tethering again to write this ***
W
p.s. I do sincerely thank all of those here for your time & efforts to help me out. But I was probably missing something in the way to a solution.
Today if I do
'sudo systemctl status NetworkManager'
I get this, for those who know how to read:
Loaded: loaded (/usr/lib/systemd/system/NetworkManager.service; enabled; preset: enabled)
Active: active (running) since Sun 2024-11-24 08:20:16 EST; 3h 5min ago
Invocation: a8ab56bf84324a1a8ecdbc5caf47be2c
Docs: man:NetworkManager(8)
Main PID: 1568 (NetworkManager)
Tasks: 4 (limit: 13896)
Memory: 14M (peak: 29.8M)
CPU: 2.116s
CGroup: /system.slice/NetworkManager.service
└─1568 /usr/sbin/NetworkManager --no-daemon
Nov 24 11:25:05 valpomar NetworkManager[1568]: [1732465505.4040] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> scanning
Nov 24 11:25:06 valpomar NetworkManager[1568]: [1732465506.8238] device (wlo1): supplicant interface state: scanning -> authenticating
Nov 24 11:25:06 valpomar NetworkManager[1568]: [1732465506.8239] device (p2p-dev-wlo1): supplicant management interface state: scanning -> authenticating
Nov 24 11:25:09 valpomar NetworkManager[1568]: [1732465509.4208] device (wlo1): supplicant interface state: authenticating -> disconnected
Nov 24 11:25:09 valpomar NetworkManager[1568]: [1732465509.4209] device (p2p-dev-wlo1): supplicant management interface state: authenticating -> disconnected
Nov 24 11:25:17 valpomar NetworkManager[1568]: [1732465517.6299] device (wlo1): Activation: (wifi) association took too long, failing activation
Nov 24 11:25:17 valpomar NetworkManager[1568]: [1732465517.6300] device (wlo1): state change: config -> failed (reason 'ssid-not-found', sys-iface-state: 'managed')
Nov 24 11:25:17 valpomar NetworkManager[1568]: [1732465517.6305] manager: NetworkManager state is now DISCONNECTED
Nov 24 11:25:17 valpomar NetworkManager[1568]: [1732465517.6310] device (wlo1): Activation: failed for connection 'COWIFI2767344348/0'
Nov 24 11:25:17 valpomar NetworkManager[1568]: [1732465517.6314] device (wlo1): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
So it says: wifi association took too long.
Hardware doesn't show any problem.
iwlwifi active. Firmware up to date.
Still searching.
W
Hi Watford,
I still think you would find some insights into your problem by studying the output of
and looking at the details associated with "Network Manager", which under the heading
Unit NetworkManager.service:
to get at some of the details regarding specific interractions and dependencies, would help pinpoint the issue.
Other than that, I would suggest trying removing the "--no-daemon" option, so that Network Manager can respond and recover from any issues of dependencies and timing on its own, without manual intervention.
Here is yet another idea. Could you use a wifi dongle to prove or falsify theory of a hardware failure resulting in that floating error?
Eric
I did read through your note of Nov 11. I tried the lines you suggested but I get nothing and not knowledgeable enough to understand all of it.
If I use: systemd-analyze dump | cat -n >dump.txt
I get.... nothing
W
Guys
I don't want to count the chickens before they’re hatched...
But it's been 2 days now without wifi connection issues... after a Nvidia update... Could be something else, but it is the only 'event' I've seen in the interim.
Lets see :crossed_fingers:
W
The output of that (dump.txt) has over 65K lines on my system in its current state.
Lines that give hints as to interactions for leads on what is breaking down where are the lines:
  8037	-> Unit NetworkManager.service:
  8062		Assert Timestamp: Tue 2024-11-26 11:56:36 EST
  8063		Assert Result: yes
  8064		Requires: sysinit.target (origin-default)
  8065		Requires: dbus.socket (origin-file)
  8066		Requires: system.slice (origin-file)
  8067		Wants: network.target (origin-file)
  8068		RequiredBy: NetworkManager-wait-online.service (destination-file)
  8069		WantedBy: multi-user.target (destination-file)
  8070		Conflicts: shutdown.target (origin-default)
  8071		Before: NetworkManager-wait-online.service (destination-file)
  8072		Before: update-notifier-download.timer (destination-file)
  8073		Before: shutdown.target (origin-default)
  8074		Before: network.target (origin-file)
  8075		Before: multi-user.target (destination-default)
  8076		Before: apt-daily-upgrade.service (destination-file)
  8077		Before: apt-daily.service (destination-file)
  8078		Before: update-notifier-motd.timer (destination-file)
  8079		After: dbus.socket (origin-file)
  8080		After: sysinit.target (origin-default)
  8081		After: network-pre.target (origin-file)
  8082		After: systemd-journald.socket (origin-file)
  8083		After: basic.target (origin-default)
  8084		After: system.slice (origin-file)
  8085		After: dbus.service (origin-file)
  8086		References: network-pre.target (origin-file)
  8087		References: shutdown.target (origin-default)
  8088		References: systemd-journald.socket (origin-file)
  8089		References: dbus.service (origin-file)
  8090		References: system.slice (origin-file)
  8091		References: sysinit.target (origin-default)
  8092		References: network.target (origin-file)
  8093		References: basic.target (origin-default)
  8094		References: dbus.socket (origin-file)
  8095		ReferencedBy: NetworkManager-wait-online.service (destination-file)
  8096		ReferencedBy: update-notifier-motd.timer (destination-file)
  8097		ReferencedBy: apt-daily.service (destination-file)
  8098		ReferencedBy: apt-daily-upgrade.service (destination-file)
  8099		ReferencedBy: update-notifier-download.timer (destination-file)
  8100		ReferencedBy: multi-user.target (destination-file destination-default)
  8101		InSlice: system.slice (origin-file)
You could then examine the segments relating to the individual segments highlighted, in the various logs, in order to pinpoint the cause of the "failed start" or the cause of the sudden "disabling/failure" of the necessary services.
Those identify all the direct dependencies for the Network Manager itself. But if the failure is not at the first level of dependency, you then need to dig into the deeper dependencies for each of those, in order to track down the point of failure, or the trigger for the unwanted offline state.
Hope that helps.
Eric
As per my previous note, I am now wifi connected...for now...
But your indications are quite interesting. I'll dig in.
Thanks
W
If you want to try different kernels, perhaps this would be the way to go: GitHub - bkw777/mainline: Install mainline kernel packages from kernel.ubuntu.com
It's available on a PPA, e.g.
sudo add-apt-repository ppa:cappelikan/ppa
sudo apt update
sudo apt install mainline
Thanks Stephen
I was to try it and then (suddenly) wifi started to connect with no glitch...
I still wonder why... some recent update(s) seems to have solved the issue. Which ? How ? ...no idea... but it works.
Maybe a 'backport' or solution sent for what seemed to be a iwlwifi or Intel Wi-Fi 6 AX201 driver issue. :man_shrugging:
So for now I'll shy away from any further actions...
Again many thanks to all of you here above
W
If you upgraded to an HWE kernel (6.11) there are driver packages for iwlwifi that will be loaded.
If you're using the 6.9 kernel that comes with 24.10 you need to install the backport-iwlwifi-dkms package to get the driver to build for your kernel. Without this the Intel wifi card will not work.
Took me about 5 hours to figure this out.
Hi, @EarlRuby and welcome to the Ubuntu MATE Community!
