I can mount this drives using command utility "mount", but i am unable through caja and gnome-disks.
Error message when trying several times.
I think it is already mounting the drives which is why it sends the message if you wait a bit it should mount, however if it still isn't accessible you have other problems
I waited for more than 5 mins , and still it says operation is already pending.
can you help me to solve this issue, or let me know where should i search for the logs?
Unfortunately I personally don't have a lot of experience with file systems they always seem to just work for me, however you may want to make sure support for them is installed, I have had that issue with a non Ubuntu MATE setup
Hi Tohid,
Surely I don't have the solution, but possibly can helps you:
- Try to use Gparted and "Verify" the partition/s.
- Try to mount with caja with ubuntu-mate-live pen. Persist?
- If this drive is used by windows, for example, as a second disc, be sure windows is
closed COMPLETELY. Enter the system and close it pressing shift permanently until
windows close.
Lucky
