Unhandled error
I got this twice today
The non techie I am have no idea what it is
Can someone figure it out for me ?
I see something that seems to refer to Zoom... but no Zoom in use when it happens
Thanks
W
Hi @Watford ,
I searched for the complete text of the error message of your screenshot:
Unhandled Error
TypeError: Cannot read property 'webContents' of undefined
at Object.onZoomChanged ([REDACTED]\main.js:316:35)
at Object.emit (events.js:315:20)
... and I found the following recent discussion (started 5 days ago) in the "Signal" subreddit of Reddit, posted by a user mentioning that is getting that exact same error message when closing the "Signal" desktop application from the "Tray Application":
https://www.reddit.com/r/signal/comments/pm2vst/getting_an_error_when_quiting_from_tray/
Are you using the "Signal" desktop application ("signal-desktop") - Signal >> Download Signal - in Ubuntu MATE? If so, is that exact same error message appearing when you close "Signal" from the "notification area" / "system tray" just like it's happening to that Reddit user?
YES! I just opened and quit and it did it.
But didn't notice any connection with Signal up to your reply.
So I won't stress over that and guess someone at Signal will adress at.
Thanks !
W
