Yesterday I’ve updated my system to 17.10 release and I had some issues that I want to share in here
DNS issue, can not load any page
The problem was with /etc/resolv.conf . For some reason system was setting up nameserver value to 127.0.1.1. This is not the first time this happen. I saw exactly the same problem when I was upgrading from Ubuntu 16.10 to 17.04 (not Mate). Back then upgrade on Mate flavour went fine. resolv.conf file is generated from Network Manager, but even when I had Google DNSes set up in the manager it didn’t affected resolv.conf. The solution was to run
dpkg-reconfigure resolvconf
This regenerated resolv.conf file and set up nameserver to 127.0.0.58 (?) and it fixed the problem.
Can any one explain me what just happen and why 127.0.0.58 works? -
Brisk menu:
If I understood correctly Martin explanations on various podcasts and in release note Brisk menu is now default menu in Mate. Why I can not see it after upgrade? I still have the old version and brisk menu seems to be missing from system -
Login screen
After upgrade user name and password window is not in the center of the screen. Is this bug or a feature?
