I am trying to figure out what sudo -i is for.
It looks like it lets you run as root without having to input your password.
But my aliases no longer work ?
My aliases are in .bash_aliases.
I think in this case the aliases need to be defined in /root/.bash_aliases as well, as the profile of the root user is being used.
sudo -i
âlogs inâ as the root user. Similar to running sudo bash
From man sudo
-i, --login
Run the shell specified by the target user's password dataâ
base entry as a login shell. This means that login-specific
resource files such as .profile or .login will be read by the
shell. If a command is specified, it is passed to the shell
for execution via the shell's -c option. If no command is
specified, an interactive shell is executed. sudo attempts
to change to that user's home directory before running the
shell. The command is run with an environment similar to the
one a user would receive at log in. The Command environment
section in the sudoers(5) manual documents how the -i option
affects the environment in which a command is run when the
sudoers policy is in use.
So under this, youâll be performing commands as the root user, so youâd be using rootâs own .bash_aliases
(as @maximuscore points out)
Take caution if youâre making changes in your ânormalâ home directory, as new files/folders will be owned by root.
thanks gentlemen for the info.
I will stick to regular sudo and gksudo.
