Using killall for Gimp
Despite my saving images in Gimp, it shows a dialog box(Do you wanna save...) whenever I exit the program.
I consider that annoying at best, a bug at wor**.
Would it be ok, to do the following ?
killall gimp
Ubuntu Mate is a great O.S.
Andy
That should be fine, assuming the process name is really just "gimp". On my UM 18.04 install it's "gimp-2.8", so make sure you adjust that accordingly.
Btw. the save dialog appears because Gimp only considers saving in its own format a "proper" save. Everything else is just an "export".
