using Mate on odroid C2. user ‘odroid’ auto login.
odroid folder has file: feh.sh
inside feh.sh are these codes:
#!/bin/bash xset s off xset -dpms xset s noblank feh --quiet --fullscreen --borderless --hide-pointer --randomize --slideshow-delay 30 /media/usb/*
it works fine when i manually run in terminal: bash feh.sh
however it refuses to work when i add in Startup App in Personal Preferences. any idea?
i tried SystemD method as well. no luck
basically i want to disable screensaver, blank screen and have FEH to load photos from usb drive everytime i turn the C2 unit on. been working on this issue for the past 15hours and still no luck.
pls help
