Very strange boot problems... installed on HDD... but can't boot?
I have no clue what is going on
I set my HDD to boot priority 1 and took out the USB boot stick and it won’t boot at all now; it just asks me to insert a proper boot device and restart. I can see Ubuntu MATE system files on my HDD, I can even see the programs I installed while it was running
I formatted my HDD when I installed it so that’s the only stuff on the drive. Do I need to specify a boot file location in BIOS in order to boot from the hard drive?
64bit architecture, the HDD install went perfectly smoothly.
UPDATE: I did a TRY boot from the USB again, here is what the Disk app says about my drives:
500 GB Hard Disk
Referred to as the /dev/sda device (partition 1 is dev/sda1 etc)
Partitioning: GUID Partition Table
  • It is partitiioned into 3 partitions and has 1.1mb of free space
Partition 1 (537 mb FAT 32bit - Not Mounted): Partition Type = EFI System
Partition 2 (495 GB Ext4 v1.0 - Not Mounted ): Partition Type = Linux Filesystem
Partition 3 (4.2 GB Swap v1 - Active): Partition Type = Linux Swap
32 GB Drive (USB)
Partitioning: Master Boot Record
Referred to as device /dev/sdb , has 47mb of free space
Partition 1 (32 GB FAT 32bit - Mounted at /cdrom): Partition Type = W95 FAT32 (LBA) (Bootable)
Some BIOS segment drives by partition.
On my BRIX, I need to go to the BIOS boot options, and there I’m presented with multiple options for the only disk the machine as, something like:
P0: Samsung
P1: Ubuntu
Can you go back to your boot settings in the BIOS and check it out?
I found that boot option and can boot into ubuntu on HDD now but i have a new problem with my sda2 partition i made a new thread for it. Thani you
