Volume control applet
Have fun with this slight malfunction:grinning:
I’m not sure, I don’t see the accessibility option in your startup apps. In the prefs (4th screenshot), was ā€œEnable assistive technologiesā€ already unchecked? If not, have you restarted your session after unchecking it?
What do you have in ~/.config/autostart?
ls ~/.config/autostart
Accessibility not in the startup apps, noting enabled, was never checked or unchecked. Here is a png of the Autostart menu ~/.conf/autostart as it is now. :confused:
No Accessibility options were in the startup apps, To my knowledge I didn't tick or untick anything. Session as been restarted numerous times. Followng png of .config/autostart.
What if you delete orca-autostart.desktop in ~/.config/autostart et restart the session? still the same?
