Wallpaper changing to default after restarting
I have been using UbuntuMATE for a while and after a recent update I just found out that for some reason the wallpaper switches back to the default wallpaper after I turn off the machine or restart it. I was hoping to get some insights on this one.
Hi @Egghead,
did you install any wallpaper changer apps?, that is the only reason it would change unless you are using an animated wallpaper set?. :smiley:
Wally, Wallch, Variety, DesktopNova and Cortina are all wallpaper changers!. :smiley:
