Weather Radar Map Stuck on Nov. 30
Using UM 16.04.1 which I just installed today. I also have the same problem with Mint 17.3. It seems that the problem is across the board regardless of what location you set up. The summary and forecast work fine. Does anyone else have this problem? Is it a problem with the Weather Channel? Is there a fix for it? Thanks.
IBM bought The Weather Channel.
I don’t see the old classic radar maps anywhere now. They must have discontinued them.
I’ll keep looking…
