In my Ubuntu Mate 16.04 I can put emblems on both the files and the folders.
I can do this by dragging it from the side panel or by checking in properties.
It’s not a big deal.
Generally, a directory will refer to all of the contents within a folder. A folder is the actual container.
I come from a Windows background.
I've tried to bring some clarity to it in this post:
Okay, so to explain the concept further to you, without using diagrams, an example of a directory from your Windows background could be ;
C:\Users\Fixit7\Documents..
where that path contains other files and folders.
An example of a folder might be ;
"C:\Users\Fixit7\Documents\Work"
where "Work" is a specific folder that contains content. The reason why there's a difference is because that folder doesn't actually have to point to your local PC, it might be a resource on another computer completely. Control Panel is another example of a folder that references items that aren't specific to a location.
So while Folders and Directories are often used interchangeably, there is a difference
Keep on learning There's something new out there every day!
Thanks for the explanation.
It is fun learning new things.
Thanks,
I also thought they were synonymous.
No, the pedant in me wants to slap you right now. That’s Cinnamon.
Mint also makes a variant of their system using the MATE desktop and aside from folder colours being better integrated in the context menu there’s nothing terribly different about Mint’s implementation of Caja beyond the superficial.
