Why are mate themes removed?
Why?
There is no reason to force yaru to all users.
kind regards bluedxca93
Why?
I think one of the reasons why yaru was removed was because, along with the NVIDIA drivers, it was taking a lot of space on the ISO, up to 4.1 GB. You can still install it from the repos i think.
Well the themes itself are less than 20mb. With icon themes maximal 60mb. There have to be other reasons.
i think you can install mate themes by using sudo apt install mate-themes
Good luck!
@Norbert_X thank you for the link. Did take a look at it.Soon ill have radiant design ported to something very close to yaru. Its more difficult than the traditional ok-/green themes but possible.
