Wi fi not working
Another thought, guessing you are using Ethernet to connect. Do you have Indicator Applet Complete on a panel. If so click on network icon and see if a wireless connection is also shown (would show with more bars and most likely would not have a lock icon like mine) and also if enable Wi-Fi is checked. Blurred out one is my WiFi connected to Internet.
Another question are you dual booting and able to boot XP or did you wipe it?
ind
ok, post the output of lspci, it should show 2 network adapters.
Here is the output of lspci:
john@john-Dell-DM051:~$ lspci
00:00.0 Host bridge: Intel Corporation 82945G/GZ/P/PL Memory Controller Hub (rev 02)
00:01.0 PCI bridge: Intel Corporation 82945G/GZ/P/PL PCI Express Root Port (rev 02)
00:1b.0 Audio device: Intel Corporation NM10/ICH7 Family High Definition Audio Controller (rev 01)
00:1c.0 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 1 (rev 01)
00:1d.0 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #1 (rev 01)
00:1d.1 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #2 (rev 01)
00:1d.2 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #3 (rev 01)
00:1d.3 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #4 (rev 01)
00:1d.7 USB controller: Intel Corporation NM10/ICH7 Family USB2 EHCI Controller (rev 01)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev e1)
00:1f.0 ISA bridge: Intel Corporation 82801GB/GR (ICH7 Family) LPC Interface Bridge (rev 01)
00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 01)
00:1f.2 IDE interface: Intel Corporation NM10/ICH7 Family SATA Controller [IDE mode] (rev 01)
00:1f.3 SMBus: Intel Corporation NM10/ICH7 Family SMBus Controller (rev 01)
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RV370 [Radeon X300]
01:00.1 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] RV370 [Radeon X300 SE]
03:02.0 Ethernet controller: Marvell Technology Group Ltd. Marvell W8300 802.11 Adapter (rev 07)
03:03.0 Communication controller: Conexant Systems, Inc. HSF 56k Data/Fax Modem
03:08.0 Ethernet controller: Intel Corporation NM10/ICH7 Family LAN Controller (rev 01)
I wiped XP
I am using Ethernet to connect.
The Applet looks different to the one you show. It has the Ethernet connection but no wi fi. If I go to edit connections it shows the WiFi connection I set up.
this is your wifi, I cannot find a suitable driver for it.
I suggest buy a $5 usb wifi adapter, plug it in to a usb port and hopefully you can have wifi.
Thanks for your help. Will do.
