Wifi and amazon prime
I have amazon prime on my tv that uses my wifi and I noticed that
Network connections shows last uses as never?
Why is that?
It would be hard to say without knowing your network setup--but, as a guess---
You probably have a WiFi router. It handles the WiFi connections. Your PC also may or may not connect to the router via WiFi. But the router has no way (nor any reason) to inform the PC that another device is also using the network provided by the router.
The only way Network connections would know is if you were wired from PC to Internet, and the PC were then providing the WiFi router and DHCP service to the TV, which would be an unusual arrangment.
Does that help?
My pc uses a wired connection.
Your explanation helped. :slight_smile:
