I’m pretty new to Ubuntu Mate 17.10. Everything is going well so far, but for one thing. My Wifi connection is pretty slow. If I do a Connection Information it tells me the speed is only 6Mb/s.
I looked about and did try this:
sudo modprobe -r rtl8723be
sudo modprobe -v rtl8723be ant_sel=1 or sudo modprobe -v rtl8723be ant_sel=2
But 1 made it go to 1Mb/s and 2 made it stay at 6Mb/s.
I also did manage to extract this information if it helps:
*-network
description: Ethernet interface
product: RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:01:00.0
logical name: enp1s0
version: 07
serial: 64:00:6a:fa:4c:c1
capacity: 100Mbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8106e-1_0.0.1 06/29/12 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
resources: irq:228 ioport:3000(size=256) memory:d1600000-d1600fff memory:d1200000-d1203fff
*-network
description: Wireless interface
product: QCA9377 802.11ac Wireless Network Adapter
vendor: Qualcomm Atheros
physical id: 0
bus info: pci@0000:02:00.0
logical name: wlp2s0
version: 31
serial: a8:6b:ad:06:57:c3
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=ath10k_pci driverversion=4.13.0-38-generic firmware=WLAN.TF.1.0-00267-1 ip=192.168.1.108 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:234 memory:d1000000-d11fffff
Would anyone be able to point me in the right direction?
