Hey there!
Have issue with wlan interface in Mate 16.04. After sleep mode i don’t see and can’t connect to Access Points. Just displaying logo of ethernet. May be somebody knows how to fix it?
Network controller: Qualcomm Atheros AR9485 Wireless Network Adapter (rev 01)
Laptop or desktop? Is the Wlan device powered off in suspend? This is usually a device specific issue. Try disabling then re-enabling the Wlan device. Many devices, including USB devices, do not work correctly with suspend. Good luck.
Hi! Thx for your answer.
Yes, i tried to disable and enable my wireless by keyboard fn buttons, but it doesn’t work.
It is Asus Laptop
