XenServer 7.0.0 Tools Installation
Sorry if I missed if this has already been asked and answered.
Can someone tell me the best way to try to get these tools install on a UbuntuMate 16.04 LTS guest os on XenServer 7.0.0?
Thank you in Advance!
Here is more. I did not give much to go from before, sorry.
[sudo] password for :
root@ubumlts:/home/# mount /dev/cdrom /mnt
mount: /dev/sr0 is write-protected, mounting read-only
root@ubumlts:/home/# bash /mnt/Linux/install.sh
Detected `Ubuntu 16.04.1 LTS’ (ubuntu version 16).
The following changes will be made to this Virtual Machine:
  • packages to be installed/upgraded:
    • xe-guest-utilities_7.0.0-24_all.deb
Continue? [y/n] y
(Reading database … 234581 files and directories currently installed.)
Preparing to unpack …/xe-guest-utilities_7.0.0-24_all.deb …
Unpacking xe-guest-utilities (7.0.0-24) …
dpkg: error processing archive /mnt/Linux/xe-guest-utilities_7.0.0-24_all.deb (–install):
trying to overwrite ‘/usr/bin/xenstore-read’, which is also in package xenstore-utils 4.6.0-1ubuntu4.2
Processing triggers for systemd (229-4ubuntu12) …
Processing triggers for ureadahead (0.100.0-19) …
Errors were encountered while processing:
