Zip files with filenames using spaces and no extension
I have been using this to zip up some icon files.
zip -u icons.zip *.*
But for a project I needed to rename some .png files to filenames using only spaces and no extension.
But now it does not zip those files?
(Engrandpa can do it, so there should be a way.
Any fix?
Well, first of all, this is a common pitfall. It is a typical MS-windows habit to get rid of:
don't use *.* if you mean *
Because *.* will only select filenames that contain a '.'
So, contrary to MS-Windows, it does what it says. :slight_smile:
so try this:
zip -u icons.zip *
Some background info:
'filename extensions' do not exist in Linux.
Not in the way that it exists in MS-Windows where it is a special entity.
(that is why *.* is valid on all files in MS-Windows, even on files without a '.' )
In Linux however, filenames with a dot in it are just filenames and a dot is just another valid character.
