xWarning: invalid escape sequence '\.'
elif re.match("^((ftp)|(http)|(file)|(rsync)|(https))://([a-z]|[A-Z]|[0-9]|:|/|\.|~)+$", uri) == None:
Traceback (most recent call last):
File "/usr/bin/software-properties-gtk", line 100, in <module>
app = SoftwarePropertiesGtk(datadir=options.data_dir, options=options, file=file)
File "/usr/lib/python3/dist-packages/softwareproperties/gtk/SoftwarePropertiesGtk.py", line 163, in __init__
SoftwareProperties.__init__(self, options=options, datadir=datadir,
File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 109, in __init__
self.backup_sourceslist()
File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 437, in backup_sourceslist
source_bkp = SourceEntry(line=source.line,file=source.file)
File "/usr/lib/python3/dist-packages/aptsources/sourceslist.py", line 509, in __init__
raise ValueError("Classic SourceEntry cannot be written to .sources file")
ValueError: Classic SourceEntry cannot be written to .sources file
I get this error when trying to load software and updates. Ubuntu MATE 24.04 but liklely it is same if happened on an non beta version. If you can make sense of this terminal output when I try to launch from terminal. Note that launching from GUI the icon appears in Plank but then disappears.
Any help will be appreciated.
