How to disable Apport's "Ubuntu has a error/problem message"
How to disable the Ubuntu Apport error message:
To disable the annoying Apport error message that Ubuntu has a problem and needs to contact Ubuntu, simply paste the following terminal command:
gksudo pluma /etc/default/apport
(Replace "pluma" with "gedit" in the above command or whatever text editor you have installed!)
Pluma will open up and you need to change this:
enabled=1
to this:
enabled=0
All you do is replace the 1 with a 0 (Zero).
Click on "Save" and then close Pluma. Sorted!. :smiley:
USE THE FOLLOWING AT YOUR OWN RISK BUT I HAVE NEVER HAD A PROBLEM DOING IT! IF IN DOUBT, USE OPTION ONE:
The other option is to remove Apport from your system, open a terminal and paste the following command:
sudo apt-get remove apport
wolfman@fred5:~$ sudo apt-get remove apport
[sudo] password for wolfman:
Reading package lists... Done
Building dependency tree
The following package was automatically installed and is no longer required:
libgnutls26
Use 'apt-get autoremove' to remove it.
The following packages will be REMOVED
apport apport-gtk ubuntu-mate-desktop
0 to upgrade, 0 to newly install, 3 to remove and 0 not to upgrade.
After this operation, 993 kB disk space will be freed.
Do you want to continue? [Y/n] y
this command will also tell you that it is also going to remove "ubuntu-mate-desktop", do not panic!, it is only removing a small file that you can live without! (Anybody correct me if I'm wrong please!).
Although it is possible to disable Apport, please notice that it is then impossible to register bugs. So please do not disable Apport on 15.04 beta 2.
Also, if you get a popup after restarting after updates, check your /var/log/crash directory for rogue crash logs that will continue to bug you unless you delete them. gksudo caja then simply move or delete it.
Another way to do that is paste the following terminal command:
sudo sed -i s/enabled=1/enabled=0/g /etc/default/apport
And Done! :grinning:
